Floplast pushfit waste
16 Jul 2009
Hull
Is floplast 40mm pushfit waste pipe and fittings a decent standard?
Wouldn't use it ... I just replaced a whole sink waste run all the way to the stack of floplast pushfit, about 4m with about 6 fittings. The reason was that when it blocked the customer unwittingly used a pump plunger, it blew two fittings off of the pipe and the mess wasn't pretty. Was DIY fitted a year ago.
Don't get me wrong, if it's properly supported and fitted it does work and it's easy to put together but for longevity & peace of mind, solvent weld is the only option IMO.
Is that a problem of any pushfit waste pipe? Not just floplast?
