FloPlast 110mm PushFit - Taking it apart?
13 Jul 2005
Hampshire
Is it possible to take FloPlast 110mm pushfit soil pipes apart once assembled? I am looking at a picture of a soil pipe in the Screwfix catalogue (screwfix part number 15484) and it looks like the socket has a metal retaining ring that might prevent a pipe being removed once it has been inserted. I need to be able to dissemble my stack in a few months time to make some modifications, hence the question.
Steve
No, it's just push fit. If it's been together a while though, the rubber seal may stick to the pipe a bit, making it difficult to get out. Some WD40 or boiling water may ease things.
Use silicone lubricant spray, WD40 isn't too kind on certain types of rubber and may eat away at the sealing ring
Cheers for the replies, I will crack on with the push fit then (lubed up with silicone first of course!)
Steve
