Flow & Return - which is which?
26 Aug 2007
Lancashire
Hi.
My DIY book tells me that there should be about a 10 degree difference between the flow and the return pipes on a rad.
I have a rad that has no hand valve covers on top so I dont really know which is the lockshield and which is the regulator. My rad thermometers tell me that the difference is just over 20 degrees, the only thing is my instict tells me that the flow pipe is the cooler at the moment.
Anyway, is there an easy way of finding out which is the flow and which is the return?
Brian.
leave the system to cool
then turn it on and see which gets hot first
Voila its the flow
Sorry to be blunt but the flow brings heat from the boiler and the return goes back to the boiler to collect more heat. So leaving aside your instinct take a wild guess at which will be the hotter.
its really nice when you get honest, straight forward, helpful advice.
Thanks Corgiman - you're a gent!
:lol: like that one
Hi.
Brian.
Only true for old systems, boilers installed today need 20
If you do not know how to find the flow and return, do not even think about balancing. Unless you want to crank up a plumber’s income
