Flue confusion
15 Mar 2016
Hi all,
Just moved into a new place, boiler is a Apollo Fanfare 15/30 which, whilst old, is working fine.
We had a gas safety certificate issued which confirms the flue is room sealed ("Flue type: R/S") and that the appliance is safe to use.
Whilst putting some stuff in the loft just now I noticed that the flue from the boiler appears to have a mesh opening where the diameter of the flue changes. Is this letting combustion gases into the attic space? Or am I missing something?
To be clear, I can see straight through the upper (larger diameter) part of the mesh.
The lower half has a solid internal wall.
Presumably you are renting the property?
Did the engineer even look into the loft?
Tony
We purchased the property and had the sellers have a gas safety certificate issues as part of the sale. Hence I don't know whether the engineer looked in the loft I'm afraid.
Thanks for the reading, explains a lot. So this setup is safe as long as it is installed and maintained correctly?
Would this be legal for a new installation?
When was the roof built as post 1985(I think) they had to be vented and were classed as outside spaces for the provision of combustion air for a vertex flue.
The house was built 1985, though I think final fitting/finishing was around 1987.
The soffits all the way around the roof have circular vents every 500mm or so, so there's good air supply into the attic.
