1CANHELP
interesting, thanks everyone. Good to get a legal perspective on things, even though I am pretty sure we won't need to go that route. Just for info, my particular road is about 7 or 8 houses that the estate agents describe as 'link detached'. I'm sure you know the form .... main body of houses are genuinely detached, but the garages sit between the houses and are attached both sides. My new flat roof extends the garage to the rear. The point is we've had the issue of access over flat roofs for maintenance ever since the houses were built.
Also, (stop me if I'm boring you), the property boundaries are quite confusing - it's impossible to draw a straight line that forms an obvious boundary between 'mine' and 'theirs' because the garages overlap the position where you'd probably draw that line. In other words, if my neighbour looks straight down his left flank wall, overlapping that line by about 40cm is the right hand wall of my garage. I've no idea how you would go about solving boundary issues around here, but I'm sure there are plenty of solicitors that would be happy to assist .....
I was beginning to wonder when I looked at the picture more closely and was going to ask if it was link detached.
Therefore, you probably have no scope to raise it due to ceiling heights inside the property.
A compromise between you and the neighbour, re-site boiler and half the cost of doing so as it can't be solved anyother way, this will be cheaper for you.
From what I remember link detached do not have defined boundaries within the dimensions of the main house bit like terraces and would normally be call the party wall where this stands with the building regs well...I don't know.
Your garden however, will have a defined boundary.
By the way, I got a flue for one of those around 10 months ago through parts center, had to ring the manufacturer though as the number in the manual has change. The GC No- for the boiler is 41-429-33. sorry manual does not do a GC No- or product No for the flue.
Also, they did a vertex flue for this model, I have never seen it and would never have believed it unless I read it in the manual, that could solve the problem of re-siting if you could get the flue system, found that out today after I rooted out the old manual.
I ment to say the number for the flue has changed from what was on the parts center computer system.
