morning all, I'd welcome advice on this little problem......
[/img]
I'm constructing a new flat roof that abuts my neighbours property - all above board, planning permission, building regs etc etc. Problem is that my neighbours flue is very close to the new roof surface, see pic above. We knew it would be close before we started the job, but since the building inspector wanted upstand ventilation the whole deck is now sitting on battens which has made the problem worse.
My neighbour is happy for me do to whatever I need to do as long as it's gas checked etc. What I'm thinking of doing is adding an elbow + vertical straight section to his flue, then encapsulate the elbow/ base of flue in sand/cement using a bit of shuttering to create a box. I'd put a slope on the top of the box and then flash with lead. I might make a lead cap that completely covers the top of the sand/cement box. What do you think? Any better ideas gratefully received! If I do what I'm planning to do should I do the sand/cement before the roof is finished? (what you see in the picture is just the first layer of felt, roofer is back to finish the job in a week or so)
TIA
Nick
[/img]
TIA
Nick
