Flymo - is there a way to bypass the cut out?
8 Aug 2006
Middlesbrough
I have a Flymo mower (the sort with wheels, not the type that hovers) that has worked very well for several years. This year it has started to cut out every few minutes. The problem seems to be that it has a cut-off switch that is supposed to cut the mower's power when the grass box is full. However, it is now cutting out when it's only about 1/4 full. When I empty it, it works again until it gets another 1/4 full! I wondered if anyone else has encountered this issue and perhaps knows of a way to disable it?! Thanks :-)
suspect the grass may be clogging the airflow have you got any filters you can clean!!!
Hi - just had the same problem but have sussed out the answer. The grass box lid has a cut out which is enabled when the box is closed, BUT if the lid is pushed upwards by the grass when full then it opens the cut out switch. Now my mower is 7 years old and started cutting out all the time, what has happened is the actuator for the cut out has worn down and the air pressure in the box is now sufficient to trip the cut out. You can test this by flexing the box lid up from the sides when closed and hear the cut out operate. The fix took 2 minutes to do by sticking a 1" length of door draught excluder on top of the grey flexible bit directly above the cut out button. Any queries then let me know. You've probably bought a new mower by now!! Rob.
