Foam/lightweight shower tray
6 Feb 2010
Blackpool
Have fitted a few stone resin shower trays on sand and cement. A weak mix the floor and shower tray both primed with SBR bond. What the best procedure when dealing with the lightweight shower that aren't stone resin. Is 1200x900 quadrant. Thanks for your thoughts
Check the instructions, I use powder tile adhesive.
Thanks so some instructions recommend that over sand and cement now? I was thinking flexible floor tile adhesive is that what you used?
Thank and do you put a similar covering of flexible adhesive down as when floor tiling. And use a 10mm notched towel.
Skillbuilder on YouTube.
Have you watched?
Not sure this covers your tray but look at the channel.
I think they have an updated talk as well.
Thank as said I have done. A few successful with sand a cement mix. But they were stone resin. Have had issues with the foam ones looking like have not totally taken to the sand and cement
Have you watched?
Interesting video that. I'll see what the manufacturers instructions say for it to be bedded on
