I have a question regarding watertight seals.
I am installing a thermostatic shower and don't know whether I am likely to have problems with a compression fitting which is not wound in tight upto it's shoulder.
View media item 39890View media item 39891If you look at the first image, you fill see the elbow connector needs to be in the position shown ie facing 6 o'clock position. The trouble with this is that it is not wound fully home on to it's shoulder as you can see in the second image. If it were then it would be facing 11 o'clock which is no good for the pipework it is connecting to. There is plenty if PTFE tape around the thread and I did need a spanner to do it up although if I could get a tight enough grip I could turn it by hand although it would be quite stiff.
My question is really, is this likely to be water tight? I mean, what do you do when you tighten up a fitting only for it to point in the wrong direction???
How tight it tight?
How tight it tight?
