Ford C Max drivers side floor flooded
16 Mar 2010
Northumberland
The drivers side floor well is soaking cant see ingress from rain but air con has been mentioned what can I check for is this common on the C Max
Grahame
Check for a build up of leaves beneath the screen in the scuttle area, and the early models had a pollen filter just below the screen, passenger side. This came with a sealing strip modification at one time, and some folks used silicone in that bottom of the screen area to prevent water ingress.
John :)
Yes gutters under windscreen clogged.
Sometimes a small flexible hose can help clear the blockage if its in the wing.
as above but there may be a small panel within the wheel arch that you can move and get your hand in to try and remove leaves and other crud.
