    Dismiss Notice
Ford Fiesta 2004 Centre Rear Seat Belt problem.
Discussion in 'Car Repairs / Maintenance' started by Luckyphil, 9 Jul 2014.
  1. Luckyphil
    Luckyphil
    12 Dec 2009
    293
    Thanks Received:
    30
    Cheshire
    Country:
    Hello all
    Back on here again looking for some guidance -
    MOT Fail , The Centre Seat belt wont pull out , so its a fail
    We ordered one via a Breaker who sent out a "guaranteed " replacement but when fitting it we have the same problem , it wont pull out even when not fitted ...... am I missing something here ??
    I realise that if you yank the Belt it wont come out , that's how its designed , But even pulling gently doesn't do the Trick
    Is it possible that the item being "thrown" about when being delivered by the Courier could have caused it to lock up ??
    Cheers in anticipation Guys and maybe Girls.
    Lucky
  2. alan333
    alan333
    5 Sep 2012
    1,304
    Thanks Received:
    253
    Glasgow
    Country:
    Assuming it's an inertia belt it needs to be at the correct alignment or the inertia lock kicks in ie if it's upside down etc the belt won't pull out. Also some belts have a self-tightening mechanism when involved in a smash. Some of these "lock up" once activated, although it's often just the front belts. If yours doesn't work when fitted then get a replacement, since it's guaranteed.
  3. Sponsored Links
  4. Burnerman
    Burnerman
    7 Feb 2008
    22,758
    Thanks Received:
    4,441
    Northumberland
    Country:
    Does the belt mechanism work properly when its not fitted? There's a locking ball device which freezes the belt, and as Alan says, it will only work at the correct angle.
    John :)
  5. Luckyphil
    Luckyphil
    12 Dec 2009
    293
    Thanks Received:
    30
    Cheshire
    Country:
    Hi Guys
    Thanks for the input , the old one locked solid and the Strap had to be cut to get it out ,
    A replacement was sent , but it was the wrong one, the Original one had what I would call standard sides
    The new one had a slot and channel where a small Cable should be installed , If the Cable isn't in situ it wont work , this was the wrong one , there is no cable within the Seat upright , So the Company is sending out a Belt to match the Original Belt
    Hopefully the replacement will work !!
    Thanks again for your input - greatly appreciated
    Lucky
  6. Sponsored Links
Loading...
Share This Page
