The indicators on my X reg Ka occasionally stop working. The hazard warning function also. It usually last a day or so, then suddenly clears itself.
I've had the two halves of the steering column off, checking the connectors under there with no success. Although on two occasions, as I was about to give up, they started working just as I was refitting the covers.
I also suspected the relay, and found it on the drawing, although it doesn't state exactly where this relay is located. I had a look on the wiring assembly/fuses in the right hand side of the drivers footwell, checking the connections with the hazards switch in the on position, again without success.
Anyone any idea where the relay is located, I'll buy a new one and swap it.
