forgot to use the knotting solution
30 Mar 2015
hi,
Having brought the knotting solution, I forgot to use it on two of my door linings and have now given it two coats of primer:(
Is there anything I should now do?
You could sand back to reveal the knots and then block them with the knotting solution. From my experiences of trying to use knotting over a primer, it isn't as successful as putting it on the bare knots.
Zinsser B-I-N can be used on top of the primer and will probably be the best for blocking knots now. The only problem is that it dries super quick, so getting a nice even finish can be tricky.
