I have some knots on an outside window frame which cause a sticky goo to tear through the paintwork.
I think sunlight is causing this.
The knots have been knotted with solution - though I suspect the knotting solution may have been applied AFTER the primer.
I have scraped back the sticky mess to bare wood. I have removed the stickiness, cleaned it up, and let dry for a few hours. I have then applied aluminium wood primer, then undercoat, top coat.
The top coat is water-based.
The surface still bubbles up into a sticky mess.
Is it more likely this has been caused by, originally, knotting solution being put over primer?
I should stress it was later scraped back to bare wood before applying aluminium wood primer.
Would Zinseer BIN or something else solve this problem?
