Fortic F1 Hot Water problems
3 Nov 2009
West Lothian
Can you help me?
I own a new-build flat with a Range Direct Fortic F1 Super Seven 1400mm (H) X 450mm (D) Combination Cylinder or similar (not sure if it is Super Seven).
The flat is 2.5 years old, after 1 year the overflow started operating, trickling or running.
The new tenants have complained that the hot water does not last until late morning - is it meant to?
They know other tenants in the same stairwell and they do not have this issue.
Between 1 and 2 years the Developer sent round Plumbers (x5) who replaced a valve and changed some settings, but nothing has changed.
The overflow runs late at night as well.
Advice is welcome before I call an engineer / plumber?
Thank you,
Bethan
its either
leaking ball valve
or the water level is set to high in the header tank
as for the water lasting
is the bottom immersion heater working :?:
and it will last for a lot longer if you don't use it
ie it depends on how much water they are using on a morning :idea:
You would need to give us some detailed information about how its heated and what timings are in place for us to give you a meaningful reply.
There is someone on here called Goldberg who by his own admission is an expert on plumbing and has fitted " many cylinders". Perhaps he will be able to say something helpful ( that would be the first time though! )
The best advice might be to call a competent plumber and get the problem sorted out quickly.
Even if you did get us the required information on here it could take several days to come to any conclusion and there is always the unfortunate risk that the post could become "locked" before the solution has been found.
Tony
