Depending on ground conditions you might get by with a 2ft wide by 1ft deep strip footings. But there's no reason why you couldn't make it 2ft deep if 1ft is acceptable.
BCO will also determine the depth of trench. Again, you might get by with 900mm/3ft trench.
