framing square/stair gauges
13 Nov 2006
Kent
Hello, I am after a product that I don't the name of in this country, In America they are known as Stair Gauges which are screwed onto the roofing square at the required run and rise measurement to keep unity on all the rafter cuts, anyone have an idea of what they are called over here in good old blighty, thanks very much
you can make your own with two strips of wood and a couple of wing nuts.
Or for the brass ones Axminster tools do them (stair gauge set) and I think Rutlans do as well
Jason
Cheers Jason, I am after a particular type, apparently the hexagon one's aren't all that, failing this I will make my own as you suggested, ta!
Sorry that I'm late to this conversation, but I find the 2 strips of wood trick to be better than gauges. The reason is that you can lay out your top and bottom steps right to the bottom of the stringer. (With gauges, you need some waste material to rest them on.)
Nigel
As it happens I was using the framing square to pitch a roof and I wanted the gauges for uniformity in my rafters etc. As it happens again, I got a pair of the Starrett gauges on E-Bay at a reasonable price, that was until I was handed the customs and excise charge on receipt "which I knew nothing about" makes them rather expensive for what they are really.
