I'm a newbie to DIY and particular boilers. I have a Glow worm Flexicom 24cx. When i first moved in to the house it all worked fine and had plenty of hot water. However not the hot water is not so forthcoming. The pressure constantly says 0.4 bar and begins to flash just after the hot water is turned on and the water starts to go cold almost instantly.
I worked out if I pressed reset and let the boiler work for about 30 mins i would get enough hot water to take a shower. I realise that its to do with the pressure but i have absolutely no clue how to fix it.
Any help would be gratefully received.
