    Dismiss Notice
Glow worm flexicom 30cx Boiler leak
Discussion in 'Plumbing and Central Heating' started by Raybell, 25 Jul 2020.
  1. Raybell
    Raybell
    25 Jul 2020
    Thanks Received:
    Country:
    Hi i have water leaking from back of heat exchanger the black plastic bit only when running hot water no fault codes or pressure drops can anybody advise please
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    13,210
    Thanks Received:
    3,019
    Daventry
    Country:
    Put your casing back on, switch off your boiler, and call in a professional. You shouldn't be accessing that part of the boiler unless you're Gas Safe Registered, and the boiler now needs to be checked for safety before it's used again. Given your description, it could well be a serious fault resulting in a safety issue which needs urgent attention to avoid it causing you harm
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
