French door in garden room
30 Mar 2015
I've managed to source a set of french doors which are 207cm high. That's the measurement of the frame and without a sill.
My challenge now is that, to keep within the 2.5m permitted development my front wall can be a maximum of 220cm. This allows me to get 2 5x2's (bolted together) above the door to get to the 220cm. This gives me a few mm for adjustment of the door. My roof will be extending 0.5m above this door.
Is it an issue to have this door fitted without a sill and will the 2 5x2s handle the door opening and weight of the 5x2 rafters and the rubber roof?
I'd appreciate any thoughts on this.
Hi, I'm from Home Energy Saving Solutions (we fit windows and doors around Manchester and Yorkshire), so bear that in mind, but no sales pitch here.
On the sill, I wouldn't fit an external French door without one. The sill is what throws rainwater away from the bottom of the frame. Without it, water running down the glass and the door leaves tends to collect on the bottom of the frame and find its way into the floor and the timber underneath, which is the last thing you want in a garden room. If height is what's stopping you, ask your supplier whether that door system has a sill that fixes onto the bottom of the frame. On a lot of systems it does, and it adds very little height. Bed it on a solid, level base with a slight fall outwards and seal it properly underneath.
On the two 5x2s, I'd be wary of anyone giving you a yes from a description. A pair of French doors is a fairly wide opening, and that header has to carry the rafters and the roof over the whole span, so it really depends on the span, the timber grade and how the rafters sit on it. A structural engineer, or a timber merchant who does span tables, can tell you quickly, and they can suggest something like a steel flitch plate if you can't go any deeper because of the 2.5m limit.
One more tip: the door frame itself shouldn't carry any load. Leave a small gap between the top of the frame and the header, pack it at the fixing points and seal it, so if the header settles a little the doors don't start binding.
Hope that helps.
Hope that helps.
Thanks for the response.
The french doors came from Facebook marketplace and it was a case of getting what was available. The doors are 207cm high and 145cm wide. Does that provide additional context around the two 5x2s that I am plannig to use as a header for this?
I understand your point re sill. In my situation, I am thinking of sticking on two pvc drips on the doors. I was planning to foam and seal the 5mm gaps around all four sides of the door.
Let me know if you have any further thoughts.
Do the doors have face drainage ( slots in the front of the frame ) or base drainage ( slots underneath the frame )? If base drainage Do Not fit without some type of cill , as water will always be draining out from underneath . Personally I'd always try and fit with some type of cill anyway
Very good point but my constraint is the permitted height. I am thinking of putting down some dpm and then resting the door on this.
My door is 207. I need to leave 1cm wiggle room and then need the 2 5x2s above it. 221cm in total.
Not sure how I can possibly accommodate a cill.
Only 2 ways I can think might help ( and I stress might ). The DPC make sure its wrapped fully around the back and sides so no water can penetrate and leave extra at the front so nothing can get underneath it. ... or have a proper lead tray constructed which will do exactly as I've described with the DpC. Whatever you do , if its base drain Do not seal the exterior edge of the bottom of the frame as you will trap water
Assume your french doors are 1600-1800 wide? Go and buy a length of square steel tube and use it as the door lintel, and def fit a sill. It would only need to be 60-80 square. Our edwardian had a piece of old railway track used as a lintel across an opening with the whole back wall above on it...! (regs? what regs?)
The doors are only 147cm wide and hence I thought that a doubled up 5x2 lintel would suffice. Let me know if you still think it needs additional reinforcement please.
I am just re-reading your message. Sorry...
A smaller lintel will give me the extra space required for a sill. Does this square tube need to be a specific spec and any suggestions on where you buy this sort of thing please?
Thanks again.
I’ve managed to source a 70x70x5 SHS length. This is obviously less that the width of the 4x2 studs. Where would this need to be situated and does it go directly above the door and then some fillets to fill the gap above and below the roof rafters?
Thanks for your help.
You need a sill.
The work around could be putting a 7x2 double in to create the door lintel, but put the top of the lintel in line with the top of the roof joists then use jiffy hangers into the back of the lintel and hang the joists in this area, should give you clearance for a sill and tolerance.
You need a sill.
I might be missing your point but my originally proposed 5x2 (doubled) would be above the door and directly on top of this would be the roof joists. I think you are suggesting the same arrangement with 7x2 (doubled) lintel. If yes, this will take me above the permitted height and that’s without a sill.
Please let me know if I’ve missed your actual point.
@mrrusty suggestion of a 70x70x5 metal tube could work as it’s saving me some space to then incorporate a sill. I just need some more details on this please.
