French doors maximum width?
23 May 2022
Hi
I have some old sliding doors I am looking to replace with upvc french doors.
They are 2040w x 2320h one company said they can make them the full width and one company said the max is 1800 wide.
Can I ask if anyone knows the maximum width or if I would be able to get away with a 2x 1020 wide doors?
Wouldn't french doors be 2 doors opening out? If it was one big door it would just be a door?
Recently had an enquiry for French doors at 2020 wide, one supplier said 1800 only, other said , yes we can make at 2020 but will require 20mm addons each side and four hinges. Could be either open in or open out.
So in answer to your question both are correct as it depends on the manufacturer, but I suspect over 2000 you will require frame addons/knockons/extenders
