    Dismiss Notice
French drain and sump pump installation
Discussion in 'In the Garden' started by pjriest, 3 Aug 2014.
  1. pjriest
    pjriest
    21 Jan 2013
    17
    Thanks Received:
    Country:
    We have a flooding problem in the back of our garden (lawn area). During the wetter months, it floods pretty badly. The area used to have a brook running through it. This has been filled in. Neighbours have tried soakaways without success. My own property has a sump pump already installed, but it's not very good. The sump pit empties and take an age to fill up due to bad drainage. I can see for example that the holes in the sump pit plastic thing are too small. On the outside the graven is very fine -- too fine to allow effective drainage, I think. I can only assume the channels that lead to this are also poorly done.
    My first plan is to overhaul the sump pit. At least 3 inches of 1/2 inch gravel around the pit and more holes in the pit liner, each 1/4 inch in width.
    My second plan is to buy a new sump pump to go in there. The float switch on the one we have is unreliable and a higher flow rate won't hurt.
    The third part is where I am coming up short. what is the best way to divert water to the sump area? Should I opt for a french drain type thing, or would a storm drain leading there be better? Any advice would be appreciated.
    Also, any advice on what I should use as the liner for my sump pit (can you buy dedicated goods, or can you just use a water butt??) as well as type / make of pump that you good folk have experienced would be great.
    Thanks a bundle.
    PJ.
  2. Sponsored Links
  3. WabbitPoo
    WabbitPoo
    26 Feb 2005
    2,759
    Thanks Received:
    141
    Gwynedd
    Country:
    Can you not just ditch the idea of a sump and drain all the water to the place where you pump it do already? (or is that uphill from the sump?)
    • Thanks Thanks x 1
  4. pjriest
    pjriest
    21 Jan 2013
    17
    Thanks Received:
    Country:
    No, we can't do that for the reason you mentioned.. The rain drain thing by the house is at least a foot above that area, plus it's about 25 meter away..
  5. WabbitPoo
    WabbitPoo
    26 Feb 2005
    2,759
    Thanks Received:
    141
    Gwynedd
    Country:
    OK
    French drains work well if done right. Have done plenty over the years. Its easy - not rocket science. :D
    • Thanks Thanks x 1
  6. hi1
    hi1
    4 May 2008
    440
    Thanks Received:
    18
    Gloucestershire
    Country:
    The flooding is presumably why the olden people put a brook in to take the water away.
  7. pjriest
    pjriest
    21 Jan 2013
    17
    Thanks Received:
    Country:
    Yep, I've seem a lot of videos and read a lot about how to do it right, so i am fairly confident that would work. In terms of a sump pump, what would you recommend? Which is a reputable make? I'm thinking that 1/2 horsepower with a 1.5 inch outlet would be plenty for this distance / height.
    Cheers.
  8. pjriest
    pjriest
    21 Jan 2013
    17
    Thanks Received:
    Country:
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
