Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have a Hotpoint future fridge rlm30 and its freezing rather than keeping food cold. the dial is on the lowest and i have defrosted it, we have also checked to see if it is blocked but it's not. any ideas
If the thermostat is on it's warmest setting, for example, No1, then the thermostat is faulty and requires replacement. The thermostats are quite cheap and they can normally be changed in less than 1 hour by a refrigeration engineer.
