Hi all
Today my front door randomly started having issues. The lock is one where you rotate a latch on internal side to lock (rather than use a key) and I've found that in final turn it's sticking badly, same applies when locking it unlocking from outside. I've checked with door open and it works fine so seems to be an alignment issue with the frame.
Looking from outside it looks the top of the door is pulled back from the frame, as if door is leaning backwards. When I pull this in manually it does lock a bit better. How do I adjust the hinges for this though? Most things I know relate to raising or lowering the door rather than brining in. Any advice much appreciated
