FSU
31 Dec 2008
Essex
Have got a double socket ,next to it is a fused spur,below is a single switch socket,the cable from the single socket goes to the fused spur at the supply side as does the double,.
My question is I want to plug in my washing machine into the single,doesn't the washing machine cable need to be connected to the load side of the fsu
Is there another cable in the single and double sockets or only one?
If there are two cables feeding each unit, the FCU may be disused.
There is a cable going from the single to the fsu,there is a cable going from the double to the fsu on the supply that is both,no cable going to load side of fsu
What I'm getting at is I want to plug washing machine into single socket,is the fsu redundand as there is nothing in the load side
You can plug the washing machine in. It does not need to be fed by the FCU, it has a fuse in its plug. It looks as if the fcu is redundant.
Cheers Winston.
What I wanted to know was the cable from the single socket ,should that go to the load side of the fcu as am plugging into socket with appliance, ie load,
Cheers Winston.
No, that cable is a spur and does not need to be fused.
Before you go rushing off to act on Winston's advice, which he gave without proper consideration, are you sure that the double socket is not itself on a spur?
How many cables are there at each accessory, and where do they go to/come from?
