Hi All,
I am having an out building fitted with a ring main and lighting running from a CU in the outbuilding which in turn will be supplied by 6mm cable in conduit from the CU in the house. i am doing the donkey work fitting the main conduiting and sockets and getting an electrician to do all of the proper connection work. My main query is about adding woodwork machinery to the ring main? I have a large band saw which has a 8.6 A rating on the motor? which the manufacture suggests a 20 AMp protection for it. i also have a drill press which i am not sure on the amp rating. Is it best to have fixed fused spurs for each machine with adequate amp coverage running from the ring main to cover this usage? i am also not sure on the total load for the CU. I will be have at least 6 double sockets plus the spurs and 2 sets of double fluorescents in the garage, with one exterior masterseal double socket too. Any tips and suggestions?
