I have a 13amp fused spur feeding a single socket & flex outlet to washing machine.
Both are behind the washing machine.
I would like to remove the single socket & fit a terminal block (15 or 30 amp?) to feed the washer FO & a new double socket above the worktop.
The terminal block would be in the back box of the removed single socket fitted with a blanking plate.
Is this method ok or is there a better way of doing it?
