fused spur under bath
8 Oct 2003
Bristol
I presume underneath the bath is a prohibited zone but what if the spur is in a wooden cupboard with a door under the bath....still prohibited?, standard 240v. Just needing to advise someone else.
If you have a bath panel which is only removable with the use of a tool then under the bath is not a restricted zone so a spur is fine.
I presume you mean a Fused Connection Unit; the cable is the spur.
A tool such as a screwdriver?, Its the power switch to the boiler in a little wooden cupboard under the bath
Yes, screwdriver counts.
Silly place for the Boiler switch but not against any regulation, as such.
Where is the boiler? Under the bath is a stupid place to to have the boiler switch, it should be accessible and within reach of the boiler.
