    Dismiss Notice
g3 panel, progamming group choice etc puzzling
Discussion in 'Alarms, CCTV & Telephones' started by vernerbongo2, 24 Jul 2015.
  1. vernerbongo2
    vernerbongo2
    5 Mar 2008
    193
    Thanks Received:
    Antrim
    Country:
    have a Honeywell g3 panel and myself and an engineer are missing something, so any idea's?
    system has 3 groups on it (1,2,4), problem is we can't program fobs to work on certain solo areas or certain combinations.
    this is how it's working at the minute:
    group 1 can't be programmed to set solo
    group 2 can be programmed to set solo
    group 4 can't be programmed to set solo
    group 1 and 4 (group choice) can't be programmed to set
    group 1 and 2 (group choice) can be programmed to set
    group 4 and 2 (group choice) can be programmed to set
    group 1,2 and 4 (group choice) can be programmed to set with any combination.
    as you can see as long as group 2 is included we have a choice
    there are no groups set on area set first in code 63 options, 2 setting logic (option 1 group mode is enabled)
    not the easiest thing to explain!
  2. vernerbongo2
    vernerbongo2
    5 Mar 2008
    193
    Thanks Received:
    Antrim
    Country:
  3. Sponsored Links
  4. GalaxyGuy
    GalaxyGuy
    7 Jan 2014
    878
    Thanks Received:
    139
    Fife
    Country:
    Group 4 is the common group. Groups 1, 2 and 3 can be programmed as individual and can be programmed to affect the common group - 4. (menu 63.1.2)
    Your question is not clear enough for me to work out your issue. You would need to detail your zone map / group map and then detail what is going wrong when you are trying to set the system.
    The G2 doesn't give a group 4 choice, as group 4 is the common group - that's where I don't understand your question.
    Perhaps posting with some pictures would help.
  5. vernerbongo2
    vernerbongo2
    5 Mar 2008
    193
    Thanks Received:
    Antrim
    Country:
    sorry since discovered its a galaxy 48 (g3) programming menu differs from g2 in menu option 63.
    Told you it was hard to explain!
    I'll try and get more info.
    In short when programming users fobs, if I give each fob holder group choice of group 1,2 & 4 all groups can be set/unset together or individually.
    If I give each fob holder group choice of say groups 1 & 4 only, they won't set/unset
    together or individually. (fob won't work)
    Same as for giving a fob holder access to say a single group e.g. 1 or 4 won't set/unset, but give access to group 2 individually and it can be set/unset as it should.
    Seems I must include group 2 in all combinations to be able to set/unset other groups!
  6. Sponsored Links
  7. vernerbongo2
    vernerbongo2
    5 Mar 2008
    193
    Thanks Received:
    Antrim
    Country:
    Just recently discovered I can have individual group control on any group if I use a programmed pin number instead of a fob but if using a fob I must include group 2 for the fob to work (set/unset).
    Eg group 1&2 or 4&2
    I'm thinking could it be because group 2 has an ordinary keypad without a proximity card reader whilst groups 1 and 4 have?
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
