Have had the above shower for around 5 yrs, and today it refuses to give any hot water. Flow reduces when Temp control turned to hot, but no heat at all. Tried all the usuals, Main Fuse OK, All wiring seems fine, and secure. The unit is getting power. Removed the Shower internal unit from the wall, and checked the Element for continuity, and this is fine. Not sure what else to do really. Am a bit miffed, as this is the second internal unit, first failed after about 18mnths, and gainsborugh kindly sent a replacement internal for £60. How long should these units last. Water not hard around where I live, but could the little boiler be scaled up. Was doing this intermittantly last week, and if switched on and off, and the heat selector moved from cold to hot to cold, all was well.
Any advice?
Any advice?
