Gainsborough Electric Shower Problem
28 Mar 2003
Was showering today with my Energy 2000x electric shower set on Medium setting when it went dead and water stopped. The fuse had tripped out. Reset fuse and shower working again but is now cold on Low and Medium settings - but hot on High setting.
Am I right in thinking the heat exchanger has two? elements and one has gone?
Is it a fairly straightforward job to replace unit with another and what make would you reccommend if not Gainsborough?
Thanks.
check your tco should have power both sides.
check heating elements for continuity.
also do a ohms test each element should be 12 - 18 ohms.
