I have the above electric shower. Yesterday it tripped out the mains. I reset the switch and everything was fine the rest of the day.
This morning, the shower works but on a setting of 3 which we normally use the water is barely luke warm although the flow is ok. If I turn it up I can get a bit of heat but of course the flow is then very limited.
Is this likely to be a problem with the heat exchanger and will I be able to get a replacement and fit it easily?
Thanks.
Robbie.
Thanks.
Robbie.
