It depends on what you have the reset levels set to. At the default levels, faults are cleared by engineer entering, viewing the fault. The fault needs to be clear too. This is complex when it comes to Comm's faults, as the next events need to go through to flush the fault out. I would use fault suppression for the comm's in menu 51. Which fault do you have ?
