Hi all,
I am trying to integrate a Paxton Net2 access control unit with a Galaxy G2-12
The issues I have had are more Paxton related but hoping someone can advise on whether I can tweak something with the Galaxy or put something in between.
My main issue is getting the Paxton to set and unset the alarm. I have discovered that Paxton is doing this based on a momentary keyswitch approach through a relay where I believe the Galaxy is not momentary. I can find no reference anywhere apart from one line in a forum post from someone stating that Galaxy is not momentary.
So the Paxton system will set the alarm as it switches the relay then switches back. The galaxy stays set however unsetting is the problem. It will unset the alarm but as soon as the relay jumps back after its momentary timeout period the Galaxy starts beeping until I enter my code. Unfortunately I cannot increase the relay delay in paxton beyond 10secs.
I'm now a bit stuck on how to approach this.
My arrangement is similar to the last diagram at the bottom of the page with the left hand relay config. https://www.diynot.com/diy/threads/galaxy-g2-20-keyswitch-zone-help.518092/
