Galaxy Power Steering
1 May 2009
Merseyside
Hi. Need advice if possible. My V reg Galaxy 1.9TDi has just developed a strange fault. In dry conditions it is fine but when the road surface is wet and I turn into a sharp corner at any speed, the power steering seems to go off until I straighten up again. Only off for a couple of seconds at most. This makes the steering very heavy and its is quite off-putting to say the least. I have had no recent repairs on the steering or suspension. MOTpassed about 3 months ago. Any ideas? Ta
your not missing your under tray are you?this is a known fault that when a service is carried out the spanner monkeys tend to leave it off,and the trouble is it is needed because of spray entering the power steering area,
has been posted numerous times on here
www.fordgalaxy.org.uk
also any other faults you may encounter then check out the site,
i own a mk 2 tdi ghia :wink: :wink:
