Could somebody explain to me what is the difference when installing Galaxy Remote Servicing Suite when it is asking standalone or network type ? I tried to find answer but never had luck with it.
No, the standalone version is the version that has its own local database. I think that's what most engineers end up using.
Some businesses even use the stand alone version centrally to the company and just remote desktop into it. This does have the limitation of only one engineer being able to work on a site at any one time.
If it's only you or you and a couple of others connecting to the sites, then the standalone version. Although it is stand-alone, it's still using a network connection to connect to the sites. It would not make sense to run the centralised version for 10 sites. It would if it was 100 sites and you had 20 engineers in different locales. I'll PM you.
