Gap around shower, advice needed!
22 Mar 2011
Kent
I've just plumbed in a shower and because of the way my pipes are there is about a 2" gap between the shower casing and the tiles. The shower is secured to the wall with long screws but I was just wondering if the gap will cause any problems and whether or not there is anything I can use to fill the gap such as some more chrome plastic etc. Would be grateful for your thoughts.
I've attached a pic to give you an idea about what I'm on about:
[/img]
omg! Can you not cut the pipes back and refit? Water will go behind and ingress into and behind the tiles, and then you will have more problems. There is not easy solution to your problem without doing a bodge.
If you want to proceed then you will have to pack it out and seal all round with a large amount of silicone sealant - Ugly! Not you the result. :LOL:
They may go directly up within the wall but they will have elbowed out horizontally to fit shower connections. If you have a couple of those tiles then I suggest you take them off and repipe behind for shower valve to fit. Retile and then fit shower again.
