Gap between connecting UB steels
15 Oct 2014
Leeds
Hello
Bit of a newbie question as first time had this type of work done, and hope I am explaining it right
The best way to describe it is that have had a steel frame erected which is in the shape of a ‘U’ style (with the legs of the U being a UB steel at the front and a UB steel at the back going into the side of the house and the opposite ends supported on a steel post.
There is a then beam that runs between these and is attached to both the front and back steels via a welded end plate and bolts.
The query I have is that where the welded end plate connection is on each side there is a gap of about 5mm to 6mm
Is this gap normal, as I would have thought they would sit flush or is this how it is normally done?
Thank you
Hello
Thank you
Steel shims?
Hi, managed to work out how to add a picture!!
Gap is at top and bottom
