Gaps with boarded aquapanel
16 Oct 2012
London
Hi Guys
I have boarded a wall using aquapanels. Problem is at the top there is a 1.5inch gap. How should I fill this ? I will be tiling.
Fill it with more aquapanel. You could also use plasterboard or ply. If the tiles aren't mosaic you could get away with tiling over the gap.
thanks for the reply. What do I use as a backing though ? Should I use tile adhesive ? Or bonding ?
Ceramic coated screws? Are they really a requirement when using aquapanel?
Gary
I suppose they have a point about corrosion and 'popping'. Chances of it happening in real life though? Stainless would do same job.
Bit of a cash cow. Another one that gets me is those green coated coach bolts for exterior use. They cost silly money when a normal galvanised bolt will outlast the timber.
