Garage Cabinets- Plywood or Mdf
29 Aug 2007
Buckinghamshire
I am going to build some cabinets for the garage based on this plan:
http://plansnow.com/dn3091.html
I will build the cabinets myself but I am unsure what is best to use for material, plywood or MDF. They need to take a fair amount of weight and abuse so which is stronger?
Finish isn't important as they will be painted. I am thinking MDF because the weight of it will add stability and its cheaper.
Any reason why I should use plywood instead?
Ply is probably 3 times as strong for relative thickness.
The main reason though would be moisture, in a garage which may not be brilliantly heated and or ventilated the moisture will make the mdf sag terribley
Thanks chaps.
I only need about 5 sheets so the price difference is only about £50 in total.
I will go with ply - nice to cut up than MDF too!
18mm waterproof ply every time, will outlast mdf regurgitated wood dust.
Wotan
