Hope someone can advise???
I have had the old fuse type consumer unit in the house replaced with a new one.
In my garage is a second small garage consumer unit that supplies power to three twin sockets and two lights in the garage. It also supplies power to two twin sockets and a light in a workshop atatched to the garage and also to one twin socket and a single light in a utility room on the other side of the garage.
My problem is, when the new consumer unit was installed in the house (by a qualified electrician), the mcb that powers the garage consumer unit continually trips!!!!
I am assuming that there is two much running off the mcb which is rated at 16a. The cable running to the garage consumer unit is 4mm.
My question is can the mcb be increaesd to prevent the tripping or should the consumer unit in the garage be changed for a larger one to distribute the power to the three seperate socket and three seperate lighting circuits?
If its the latter will the 4mm cable running to it be ok or changed for a larger one and will the 16a mcb at the house consumer unit need increasing?
Any advice greatly appreciated
