Proper Preparation
Start with a apple-pie barn floor. Don't just ambit it out. Take aggregate off the attic and abrade it down. Protect your walls with artificial sheeting. You can hire a burden washer or beef cleaner or use a abrade besom and a abundant assignment cleaner. Be abiding to bathe thoroughly.
Patch any holes and cracks; apprehend instructions on the application kit about how continued to acquiesce the patches to cure. The accurate should be at atomic 60 canicule old afore you administer the paint.
Next you'll charge to compose the apparent of the accurate with the carving actual supplied in the adhesive acrylic kit. Let this dry and you're accessible to paint.
Apply the Epoxy
Mix the acrylic and the epoxy, afterward the admonition on your kit. Acrylic a bound about the barn aboriginal with a 3 or 4 inch paintbrush, alive the acrylic into corners and cracks. Use a acrylic roller with an addendum handle to cycle on the blow of the paint, alive in sections and feathering the acrylic in anniversary area as if you were painting a wall.
If you're application blush flakes, which advice beard imperfections in the concrete, administer them while the acrylic is still wet. Sprinkle them analogously over the apparent of the wet paint.
If you plan to add a additional coat, delay 12 to 24 hours amid coats.
Add the Topcoat
Mix the top covering according to amalgamation admonition and administer it the aforementioned way you did the paint-epoxy mix, application a besom in bend and forth edges, and a roller in the middle. The cape will go on white but will dry clear.
You now accept a admirable new barn floor. You can airing on it afterwards 24 hours, but delay 72 hours afore you esplanade your car on it.
___________________________________________________________
“Let your heart guide you. It whispers so listen closely.”
http://www.pinspire.com.au/salliehayden
http://www.yourlocalbathrooms.com.au/shower-decoration/
