I am in the process of a garage conversion and need advice. The floor slopes from back to front i am using 50mm kingspan and timber battens. Can anyone explain how i overcome the slope. (will be using t&g chip board on top.
You'll need to use tapered timber battens (if its not too much of slope?) which you can get done at a local timbermill or you'll need to use slightly diminishing sized battens/joists as you work accross the floor, have buiding control approved your 50mm Kingspan? sounds way too thin to me.
