- Joined
- 7 Nov 2023
- Messages
- 24,848
- Reaction score
- 16,192
- Country
I put mine in the bath, its so much easier than stretchingI've got one I can reach it whilst in the bath.
If you read you copy of the regulations carefully you will see that BS 7671 does not need to define every single piece of electrical hardware in Part 2 because Regulation 511.1 requires that every item of equipment selected and erected must comply with the appropriate British or Harmonized Standard.Which is not the same as [etc]
- When a manufacturer builds a batten fitting, they cannot test and CE/UKCA mark it against a lampholder standard. They must certify it to BS EN 60598 (Luminaires).
- When a manufacturer builds a pendant socket, they certify it to BS EN 60238 or BS EN 61184 (Lampholders).
- Because the hardware itself is legally defined and certified by its product standard (listed in Appendix 1 of BS 7671), an installer cannot reclassify a certified luminaire as a "lampholder" simply because BS 7671 Part 2 doesn't list the word.
As:
OP wishes the fittings to be moveable and
if they are marked as double insulated and
only require L&N connexions.
An obvious answer could be to provide a socket and plug for each fitting.
CPC as far as the socket
twin flex from there to the fitting
easy to move out of the way.
That is open to interpretationOr T/E to a junction box and 2C flex from there.
So what? There is no way you wired all those lamps yourself. It is a purchased luminaire fixed to a point having (one would hope) a CPC equipped. It has no bearing on your silly argument against the regulations. Stop being so childish!
A short link from a JB by every light would be OK
But running flex from light to light and clipped in is a NO because the twin becomes part of the permanent wiring.
So what?
Only someone stupid would think I was saying he could use 2-core flex in the circuit to the point where the flex to a suspended light fitting was connected.
