I have an integral garage that is about 100mm wider that the up and over door that makes up one end of it. At the moment there is contact on the door and a PIR in the corner pointing across the up and over door and along one of walls.
When opening the up and over door it hides the PIR sensor from about 10% to 90% open and I can't really see another suitable position to move the sensor to to improve this!
It would obviously detect someone cutting through the garage door and walking in or the door being peeled in one corner.
How would you pro installer chaps normally cover this off? Move the PIR, add a second door contact, leave as is etc?
