Garage PIR position
23 Jun 2006
Hampshire
I have an integral garage that is about 100mm wider that the up and over door that makes up one end of it. At the moment there is contact on the door and a PIR in the corner pointing across the up and over door and along one of walls.
When opening the up and over door it hides the PIR sensor from about 10% to 90% open and I can't really see another suitable position to move the sensor to to improve this!
It would obviously detect someone cutting through the garage door and walking in or the door being peeled in one corner.
How would you pro installer chaps normally cover this off? Move the PIR, add a second door contact, leave as is etc?
If it was a wired system ( ie not dependent on batteries in the sensors ) then my ( non -professional ) suggestion would be a break beam sensor acrros the door about a foot above floor level. ( assuming any peeling would be at ground level and the intruder crawls in ).
Mine was fitted in the far corner, pointing back towards the door.
Unless you're a burglar, in which case I'm not telling you where it is, and beware Fang and Satan... They're always pleased to see us but I don't fancy a strangers chances.
I've got one of these on the garage ceiling for exactly this reason: https://www.riscogroup.com/products/family/124 You can often pick them up on eBay for less than a tenner. Note that the microwave will need very careful adjustment to avoid picking up people walking past outside the garage door!
