Garage roof too shallow, causing damp wall...
11 Apr 2006
Berkshire
My garage is detached from the house, and is around 4M wide and 6M deep. The roof is single pitched and done in what looks like a modern form of corrugated metal. It's very similar to this:
The problem seems to be that the drop is only around 4cm across the entire 4M width. In light rain this appears to cause the rain to reach the edge then run backwards on the underside of the metal, in to the wall, rather than forming droplets and landing in the guttering.
So, all the render has blown, and the inside of that wall is always wet in winter (despite it having DPC at the bottom of the walls etc)
Are there any tricks to solving this? I was considering running a bead of silicone under the roof at the lip so that the water wouldn't be able to run back on itself, but I'm not sure how long it'd last.
Cheers
Gary
You can get filler units to suit the profile of the sheets.
Have you checked it is not condensation?
