Hi All,
I want to install a water feature, and some lighting in my garden.
I plan to connect to the garage electrics, which is wired from the consumer unit in the house to an RCD in the garage (Via shielded cable)
The garage has two radial curcuits - 1 for light, 1 for power.
Currently its like this...
(Excuse the cr*ppy diagram, hope it makes sense!)
____
RCD|----|SWITCH|----|STRIP-LIGHT|
RCD|----|DBL-SKT|----|DBL-SKT|----|EXT-SWITCH|----|OUTDOOR-LIGHT|
I plan to add a junction box to between the double sockets, this will feed a double exterior switch, from which the lights and fountain will be powered.
I havent investigated the lights yet, I appreciate these may low voltage be fed from a transformer, so it may be a case of having the transformer in the garage, with both the mains and low voltage cables coming out of the garage.
I would appreciate any ideas/views/advice on all of this.
Cheers!
Simon.
____
Cheers!
Simon.
