I have an outside tap fitted in my garage. It is fed from the cold water tank in the loft of our cottage (about 3m above ground level) via about 10m of 22mm pipe and then about another 4m of 15mm pipe and then finally through a washing machine isolation valve and onto the tap itself.
Needless to say that, after an additional 10m of garden hose, there is little more than a trickle from the end of the hose pipe.
My longer term plan is to run a proper mains water connection to the bathroom and garage via some 22mm pipe and then install a tap directly to this (rather than via the washing machine valve).
However, until then I was wondering if a pressure washer would help at all? Obviously it would have one hell of a tough job pulling the water through all that pipework but I guess that this is what they are designed to do since they tend to sit on the end of meters of kinked hose pipe.
Cheers,
ip
Cheers,
ip
