What is the best way to run cables to garden structures that are to be built.
These are just hypothetical questions and do not relate to real jobs.
Path lights.
SWA to an IP rated box, then feed the lights. But you can't terminate SWA to these fittings. All the ones I have seen are rubber flex, which has been buried. Does not seem right to me. even if the flex was in conduit how do you deal with the conduit meeting the light fitting.
Brick pillar. Buried cable inside the pillar. How is this best installed.Again I would thing SWA to base of pillar, terminate in a suitable enclosure then would you run a length of conduit through back of enclosure then right angle bend up the inside of the still to be built pillar, then right angle bend out to pillar front.
timing with the bricklayer seem the issue here.
Never worked with a brick layer. Is it common for them to build in conduit runs
Sorry if this sound real stupid but what is the best way to run cable in these situations
Path lights.
